door locks are freezing up - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-02-2013, 05:07 AM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
has this happened to anyone else?
mine are at the point where i can get the key in but can`t even turn them.....
going to pull them and see if i can get them working again
Wes
2010 F350 CCLB 4x4 Lariat Sterling Grey
11 and up Console upgrade
2 1/2 levelling kit
1995 F350 CCLB XLT Stock for now....
1997 F350 CCLB 4x4 5 speed Tourmaline green
DDP Stage 1`s
08 Bucket console upgrade ( SOLD )
Ranzan is offline
post #2 of 7 Old 04-03-2013, 06:30 PM
Mine did that i just loaded them up with graphite lube, they work fine now
Bulldog.68 is offline
post #3 of 7 Old 04-04-2013, 04:27 AM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
thanks bulldog i did that awhile back guess i will be doing it again
just seems strange that they are freezing up that bad
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
post #4 of 7 Old 04-04-2013, 09:04 AM
Quoted: 44 Post(s)
Heat the key up with a lighter and slide it in (wear a glove!).
Does the little shutter for the slot close completely?
Could be water/snow coming from above, from the window moulding.
madpogue is offline
post #5 of 7 Old 04-07-2013, 08:15 PM
mkeith54's Avatar
I had to pull the locks out the doors and clean them. I used a Harbor Freight ultrasonic cleaner and simple green. I live on a gravel road and the fine dust gummed up the locks. After a few cycles they freed up and now work fine.
Mike Keith
New Florence Mo
1996 F-250 ECSB, 6-pos/ts chip/ Tymar intake
Pyro, boost, and tranny gauges
mkeith54 is offline
post #6 of 7 Old 04-07-2013, 08:20 PM
nohsp4u's Avatar
Try tri-lube,or another brand of Dry lube spray. you can get it from hardware store. Do not use WD-40 unless you owe your local Locksmith.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #7 of 7 Old 04-08-2013, 05:17 AM Thread Starter
Ranzan's Avatar
Quoted: 20 Post(s)
thanks guys will give them a good cleaning once the truck is back from the body shop
Wes
2 1/2 levelling kit
DDP Stage 1`s
Ranzan is offline
