Looking for pics of roll pans - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-28-2013, 04:48 PM Thread Starter
JD3020's Avatar
Thinking about going to a roll pan on my truck, but not 100% sure yet how i feel about the looks. So if you've got a pan on your truck, lets see it!
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #2 of 5 Old 03-29-2013, 07:11 PM Thread Starter
JD3020's Avatar
Bump
damn 10 character limit
Jimmy
JD3020 is offline
post #3 of 5 Old 03-29-2013, 07:59 PM
JBRIXEN's Avatar
my old F150
95 F350 CCLB, ZF5, 6637, MBRP dp to 4", GTP38, intercooled, 3" plenums, DIY E-FUEL, TE17*, TS 6 pos, 140v IDM, boost fooler, leveling kit, 315/75/16's, boost, pyro, oil temp
JBRIXEN is offline
post #4 of 5 Old 06-08-2013, 03:13 PM
Try Bronco Air
The site BroncoAir.com sells a rear roll pan and has several pics.
1997 F350 Black & Lifted CCLB OBS PSD
Purchased Sept. 2012 w/183,000 miles
deanc24 is offline
post #5 of 5 Old 07-01-2013, 06:15 PM
tjl
tjl's Avatar
My dually with a Cervini's roll pan.
With hidden hitch
'96 F350 CC dually 5 speed w/short throw shifter, '03 sd intercooler, stage 1 injectors, D66 turbo, 6 POS chip with Tony Wildman tunes, T500 HPOP, CCV mod, gutted EBPV, modded ID
tjl is offline
