| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
F-250 HD leveling kit
I have a 250 with the Heavy Duty package. I liked it because it pulled the horse trailer easy but i dont pull it any more and i dont like how its sitting with the a** end up how big of a leveling kit do i need to make it level
The HD pkg doesn't mean much,actually it doesn't mean anything other than you have a 97
But you can go with a single add-a leaf or with a mini pack. either one will give you 1.5-2" |
There aint nothing heavy duty about the f250 front end. Thats for damn sure.
It really depends on if you have a 4x4 or 4x2. The 250 4x4 had a TTB Dana 50front that can't easily be lifted due to the way it bolts to the crossmember under the engine. Your best bet if you have that axle is to either remove the rear block or swap the D50 for a D60.
Here is my 95 250 without the rear block on stock tires. ![]() Same truck with a D60 and 35" tires.
Re: F-250 HD leveling kit
This is right after the leveling add a leaf lifted front two full inches
Sent from my DROID RAZER HD while trucking |
An other pic of it
Don't mean to high jack the thread, but what is the best brand for "add a leaf" and how hard are they to install? Could I do it myself with basic tools? (I know it will need to be realigned)
Can anyone comment on the quality and ride of this mod? Sent from AutoGuide.com Free App |
Does anyone make a 1-2" leveling kit fer my 2wd 97obs?? If so what does the kit consist of??
I'm wantin to get 35" all terrains under my truck. If I put 35s under there will I have to adjust my speedometer/odometer?? Sent from AutoGuide.com Free App |
To fit 35s with out shimming bumper your gonna need 3" if not 4" over stock, my 33"s rubbed hard on turns
