Largest tires on a stock 4wd - Ford Powerstroke Diesel Forum
Old 12-22-2007, 07:59 PM
Well, its about that time.... time for new tires. Ive got a 94 f350 crew cab long bed, and im trying to find what the largest size tired i can go with, without too much rubbing. I do NOT offroad the truck, it hardly ever will see any weight in the bed, and the trailer it tows on a weekend-basis has a tongue weight of about 500lbs at the most. Overall, I really didnt need a 1 ton, but the price was right. I use the truck pretty easy.
So what have you boys figured out? Whats the largest tires you can throw on a stock-height OBS f350?
Old 12-22-2007, 08:15 PM
say no to rolling coal
I have no idea about an answer to your question, but here's a bump for you.
Old 12-22-2007, 08:25 PM
back to business
I've got a 96' f-350 cc lb gasser , I'm running 33's with no prob. and it DOES get off roaded . I think 35's would come real close to fitting, but you might rub a little. Anyway, I'm no expert, just my opinion. hope it helps a little, and good luck
Old 12-22-2007, 08:27 PM
I have excessive flatulance!!
Send a message via AIM to Diesel Nick
i'm running 305/70/R16's they are 32.8 inches idk if you can go bigger i wanna find this out too cuz I need new tires really soon... so here is a bump
Old 12-22-2007, 08:42 PM
cj41foleyisathief
I would think 285's
Old 12-23-2007, 10:01 PM
ive got a stock 2wd f350 and just put 33/11.5-18s on, with very minor rubbing on pass bumper. i dont know how much higher a 4wd sits but i would think you could fit 35s with the right backspacing
Old 12-23-2007, 10:06 PM
KVFD
i get 295's under my truck heres a pic maybe u will like:
Old 12-24-2007, 09:26 AM
thanks guys.... i think im going to try a set of 33x12.50s and see how i make out with that.
Old 12-24-2007, 10:49 AM
i have a 97 powerstroke 350 and i have 315/75/16 on mine and only had to trim a little off the corners of the bottom of the bumper
Old 12-24-2007, 11:10 AM
I have an 06 F350 and am running BFG LT285/65R18.
