| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
bed tool boxes?
I use my 95 f350 Crew drw for towing a 40' enclosed gooseneck to haul 2 competition rock crawler rigs. I need plenty of room to carry tools, spare parts, and what not. I've seen low profile truck bed tool boxes but can't find exactly what I want. I DO NOT want shiney diamond plate aluminum or even black diamond plate aluminum. I want smooth steel either black or white with strong quality latches that don't look like you could pry them open with your pocket knife. Need the crossover box to sit on the bed rails so I still have the ability to haul 8' lumber but want it low profile so it doesn't block rear vision. Also I want "porkchop" (sit on top of and extend behind wheelwells but not above bed side) boxes from the same material and same quality. Ebay is chocked full of cheapo boxes and that's not what I want. Suggestions?
check tractor supply
Northern tools carried a deep slim line box. 72"L x 14"W x 18"H in black.
If you want high quality stuff look into weather gaurd. Its great stuff but rather expensive. Northerns good line is awesome too
Or get a diamond plate unit and have it Rhino lines. I have a 90 gallon transfer tank that is L shaped and my diamond plate box sits on top...the next step is to pull it all out and get everything Rhino lined. I have seen it done and it looks really good. Yeah, the hardware is a little crappy, but I think that I can upgrade that over time.
Portable Generators, Heaters + Wood Stoves, Snow Blowers, Pressure Washers | Northern Tool + Equipment check it out they have some nice stuff
Personally I like the "chest" style that don't sit on the rails, I just block them up from the bottom so they are level with the bed and like you said i can still haul a 4x8 sheet of whatever if I need. Just my 2 cents.
