| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
1997 srw stroker tires
i am currently runnin 285s bfg all terrains and they rub pretty bad but they make my 2wd look like a 4wd (and ride like one) they are fine in the back but rub almos every time im in a parking lot on the front ones what size sould i put? i also have stock wheels
Where do they rub? If it's the front bumper you can cut the bottom corner off to stop them from rubbing. When done correctly you can't even tell that it's cut.
My 97 4x4 F350 will fit 35" tires with the bumper cut. jim |
ya my bf allterains rub in my 2002 i have 295 under it
they dont rub the bumper, that would be real easy to fix. it is when you turn the back of the tire rubs on what i think is a sway bar ussually in parking lots and when you go through a turn at a pretty good speed it might do it
can i just grind whatever part is rubbing or will that just f*** everything up?
pictures always help
yes it is metal and i think it has something to do with suspension (it is a real pain in the *** parking when you cant turn the damn wheel to lock(dont have a digital camera)
