| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
I was lookin to get a new set of rims on my truck I have a 6in lift and 35's with no rubbing issues what so ever so I would like to get a new set of wheel and keep the same backspacing but my question is what backspacing do the stck alloys have
bump just want an opinion dont care if you know what your talking about either
If I can remember, I'll check at work for ya tomorrow.
what do you mean backspacing? how wide of a wheel or tire?
Alright man, I looked it up at work today and factory wheels has an 11 mm offest (thats the backspacing). Hope this helps in your hunt!
hey thanks alot man that helps
jim |
Well, i'm not 100% sure if its mm or cm but i work for discount tire and the computer said that factory backspacing was 11.
Offset can be positive or negative, so there's a +,- in that number, tha backspacing will be, the half of the wheel width, plus/minus those 11 mm |
That sounds quite odd, 11mm offset it's ok, but the backspacing is usually mesurend in inches...
