how high?????? - Ford Powerstroke Diesel Forum
Old 11-19-2007, 04:29 PM
how high??????
How high can I go on a 95 F250 before i have to lengthen my driveshaft and all that stuff? and what else do you have to lengthen?
Old 11-19-2007, 04:31 PM
i would say 4".... and the stuff you would have to lenghten is both front and rear driveshaft, brake lines, and depending on what tires you went with remember gears are a must....
Old 11-19-2007, 04:52 PM
BIG TRUCK, SMALL DRIVER
I agree, 6" is possible with relocating the brake line brackets, but the slop yolks will barely be holding on. It will be drivable, but I'm not sure how much abuse it would handle.
Old 11-19-2007, 05:03 PM
Im not sure on 95, if its the same set up as a 99 we got 8" of lift on a 99 and didnt lengthen any drive shafts. Just brake lines and cables.
Old 11-19-2007, 05:05 PM
how is that possible... i had to lengthen my front driveshaft 2.5".. no way it would of reached with out it...
Old 11-19-2007, 05:08 PM
IU Hoosier Fan
well Raul... with my 8'' lift I only had to lengthen the rear dirveshaft not the front one...
I noticed yours is a extended cab, my brothers is a standard cab. I think he also had a drive shaft spacer?
Old 11-19-2007, 05:15 PM
See signature...I am running a 6" lift on an '00 Ext cab short bed and have more than enough of my slip yoke engaged. It gets beat on regularly and hasn't given it up yet. Only my brake lines are lengthened.
-Aaron
Old 11-20-2007, 03:34 PM
i have about 8 inches of lift and haven't had to lengthen my driveshafts, and i am hard on my stuff. do have longer brake lines tho.
