Trimming OBS bumper - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-18-2007, 08:00 AM Thread Starter
SMKSTAX's Avatar
Trimming OBS bumper
Okay if I get some extra money soon i'm gonna put some 37's on the ol' 97. Think i'll have plenty of room seeing that it's a 350 and sits pretty high to begin with. The only spot I see that could be an issue is the bottom corners of the front bumper. I'll just take a cutting wheel and trim off the amount I need for clearance but my question is what do you do with that edge that's trimmed so it does'nt rust up?? Any ideas?
And hopefully the tires don't hit the leaf springs at full lock. LOL
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #2 of 8 Old 11-18-2007, 09:42 AM
Sam Burton's Avatar
just throw a quick shot of paint on it, mask off the chrome part and go to town. i haven't trimed the bumper on my diesel but i have done it on other trucks i've had. you have to redo it once in a while but it works.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 8 Old 11-18-2007, 09:48 AM
Raul@Stealth Automotive's Avatar
not sure about the paint but the only non lifted OBS trucks i have seen that fit 37" tires are the ones with cut out fenders.... just a thought
Raul@Stealth Automotive is offline
post #4 of 8 Old 11-18-2007, 09:48 AM Thread Starter
SMKSTAX's Avatar
Just like a flat black I guess? Would ya spray a shot of primer(rust inhibitor) on it first?
RICK
SMKSTAX is offline
post #5 of 8 Old 11-18-2007, 09:49 AM Thread Starter
SMKSTAX's Avatar
Hmmmm might have to do the shackle lift then first. Thanks Raul. Thought i might get away without doin that.
RICK
SMKSTAX is offline
post #6 of 8 Old 11-26-2007, 08:58 AM
screech's Avatar
The owner before me had made blocks he put between the bumper and the frame mounts. It moved the bumper forward close to an in. I have since lifted and added 35", but 37" with no lift???
96 350 Reg.cab 7.3 5sp. 4x4
3.5 to 4in dp, 4in strait pipe
4in Superlift w/ Airlift airbags on 315/75/16 Procomp X-Allterain W16x10Procomp wheels
Ba### Technicooler(the bad word)
Boost & E.G.T. Guages
Superchips programer(for now)
fpr mod
d.i.y. intake
South Bend clutch
79 150 4x4 (my wheelin truck)
420ci M motor,c6
4in lift, 35x12.5x15 Mud Terains
was old driver too much $$$--6-9mpg of premium(11.5to1)
screech is offline
post #7 of 8 Old 11-26-2007, 09:27 AM
rankroddin250's Avatar
my budddie was able to clear 35's with an adaleaf in the front and a trimmed bumper. I would suggest at the verry least a 4 inch lift to run 37's but thats just my 2 cents.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #8 of 8 Old 11-26-2007, 09:47 AM
squeeks's Avatar
My 35's Fit fine, all that had to be done was Add a 1-2 inch spacer to move the Bumper forward a little bit, i think it works out better this way cuz then you have a little better foot step to look over the motor. For 37's i would definately recommend at least the add-a-leaf to get them to fit
1996 Ford F350 Regular Cab 5spd with the 7.3L PSD, 4x4, 35.5x12.5x16.5 All-Terrain T/A's, 3.73s', DIY Electric Reg Return Fuel Sys, 3" Downpipe, AFE Stg 2, 17* HPOP, IDM Mod, SB Con-O, Cat and Muffler Delete, AutoMeter NV Series Boost, Fuel Press. and Pyro, Autometer 3 Pod A-Pillar, TS Performance 6 Pos Chip. HPX Mod, 335,000 Miles
squeeks is offline
