Headlight wire diagram - Ford Powerstroke Diesel Forum
Old 11-12-2007, 02:19 PM
Anyone have a link handy to the wire diagram for the headlights?
I have a 1995 250 that used to be a plow truck.
I changed the glowplugs and by bumping that mess of wiring I now do not have any headlights. I figure I'll give it a go and then if I can't fix it I'll just rewire them from the switch.
So thanks in advance!!
Old 11-13-2007, 02:55 PM
7.3 tech, supporter
Coming from the fire wall there is a red wire with a black tracer and that sould be the high beam circuit. there is also a lt green wire with a black tracer, this is the low beam circuit. That might be backwards but you get the idea.
How are the plow lights wired?? Do they come on with the headlights or do you have a switch to toggle between headlights and plow lights??
Old 11-13-2007, 03:10 PM
BIG TRUCK, SMALL DRIVER
Have you checked the fuses?
