door hinge pins - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-11-2007, 01:03 PM Thread Starter
paulmacjr's Avatar
door hinge pins
i just ordered a pin kit for my truck, because the old one wore out for the door hing and was wondering how do you get the pins out, so i can put the new ones and fix my saging door problem? "back up plan-
if all else fails i will have to cut then out with the trusty sawzal"
any lite on the subject would be help full
paulmacjr is offline
post #2 of 5 Old 11-11-2007, 01:09 PM
fishingjred73's Avatar
on the older vehicles you just took a punch and hammer and drove em out. But i haven't changed any on a newer vehicle.
02 F-350 srw cc
DIY tymar intake
08 bed mod
fishingjred73 is offline
post #3 of 5 Old 11-11-2007, 01:10 PM Thread Starter
paulmacjr's Avatar
when you hammer them out do you put alot of wd40 on them and then hammer them out?
post #4 of 5 Old 11-11-2007, 01:13 PM
if a little wd40's good then a lots goota be better Yea i'd spray emdown and let em soak and be sure to have somebody holdin on to the door when you knock those pins out
02 F-350 srw cc
DIY tymar intake
08 bed mod
post #5 of 5 Old 11-11-2007, 01:17 PM
I just went and looked at my hinge and it doesn't look like you can knock them out. They have like a cap on both ends. The ones you could knock out usually had a point on the bottom. Have you got the kit already or waiting on it. Be sure you got new bushings to go with the pins.
02 F-350 srw cc
DIY tymar intake
08 bed mod
