| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
putting f350 front springs on a f250
Can I buy OBS f350 front leafs and put them on my 95 f250?? I want to lift my truck just a little so it sits like a f350
Springs wont help you, 350 springs actually have a lower rating than 250 springs
so whats the cheapest way to get my truck to sit like a 350?
The best way is to swap a D60 into it and the rear blocks from a 350
The cheapest is to add-a-leaf and get the wheels realigned so the camber is right. |
whats the difference between blocks from a 250 and 350 and what add a leaf do I need to match up with 350 blocks so it sits level??? truck sits level now stock..
250 blocks are 2"... 350 blocks are 3.75"
so it will lift the back of the truck 1' 3/4 , so what should I get as a add leaf for front?
if only adding a leaf to the fron you wont need anything in the back, the rear is if you put a D60 front end in
If I add a leaf to the front wont I need somthing in the rear so it sits level? The truck sits level now I just want it about 2 inches higher and I want to maybe run 285s or 315s
Why not just lift it? I think lift kits are fairly cheap.
You have to forgive us, we dont know what your truck looks like and are only going off what we are told which is sometimes hard to visualize |
