How to take the u joint off the axle and stub shaft? - Ford Powerstroke Diesel Forum
Old 12-29-2012, 01:01 PM
I've the the hub and everything apart and pulled the inner axle out I'm just not sure how to get the u joint out now since I need to replace it and the stub shaft... Any help would be greatly appreciated
Sent from my iPhone using AutoGuide.com App
Old 12-29-2012, 07:46 PM
You 1st need to remove the INNER C-clips that hold the u-joint cap in place. THEN you can drive the u-joint caps out
