97 Powerstroke Hood Stuck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-29-2012, 11:15 AM Thread Starter
Robin's Avatar
Slamed my hood shut last night and noticed in hadn't closed all the way this morning.
Tried pushing the rest of the way down and it will not catch, stays partially closed as on the safety catch. Reached through grill to release so I can raise to inspect but the saftey catch lever will not move to the release position (towards the left.) Checked release in cab and iit doesn't seem to be engaged ( it just pulls out with no "click" or resistance) Hood will not open......any suggestions?
Robin is offline
post #2 of 5 Old 12-29-2012, 02:11 PM Thread Starter
Robin's Avatar
Found previous threads and unbolted 10mm latch bolts through the grill. Then I shaved i/4 off the black plastic table between grill and latch to allow a 1/4 inch ratchet to fit in their next time this happens. Good preventive procedure for you to do NOW.
Robin is offline
post #3 of 5 Old 12-29-2012, 02:35 PM
kramarj's Avatar
Just make sure the latch doesn't get closed before you close the hood. Had it happen twice and both times sucked. I ended up taking a prybar against the latch and beat it over with a hammer.
My Truck
97' F-250HD. ECLB. 66,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
My Dad's
97' F-250HD. ECLB. 18x,xxx miles. 7.3. E40D. 6637 Filter. 4" Exhaust. TW Tunes. Work Truck.
97' F-250HD. ECLB. 150,000 miles. 7.3. E40D. 4" Exhaust. Work Truck.
kramarj is offline
post #4 of 5 Old 12-29-2012, 04:10 PM Thread Starter
Robin's Avatar
Thanks but I wound up reaching through the grill and taking the 10mm lacth bolts out which was tight! In case this ever happens again I have cut some of the black plastic out between the grill and the latch so that next time a 1/4 ractchet will fit up in there without cuting your wrists getting the wrench in there. This would be a recommended preventive procedure for any one to do before the latch lock happens.
Robin is offline
post #5 of 5 Old 12-29-2012, 05:34 PM
Quoted: 50 Post(s)
Pics of this cut? Sounds like a good idea, but having trouble picturing it.
madpogue is offline
Tags
body , hood stuck
