| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
Does anyone know where i can find a good set of those diamond clear headlights and the clear lower turn signals. Not the upper corner ones the lower piece below the actual headlight. I have seen this on a truck that went by and i need them.
Any of the little stereo/rim/riceburner shops should be able to order them for you.
I think they call those euro lights and the turn signals are LED euro if you get them post a pic of them I would like to see them
i've had luck on ebay with replacement/ aftermarket headlights....also, the turnsignal under the headlight and the corner marker are all one piece, unless you know something i don't...good luck
Might be a little late on this one but if you want headlights and turn signals like mine. If you got to my garage and look at the pic of the front corner view you'll see them. If these are the ones youre talking about I dont remember where I got 'em from but they are from APC.
beware of cheap quality....
I like the look of aftermarket lighting as well as the next guy. But i've had literally crappy luck with them. It's all supposed to be just like factory, but it isn't I don't think. Hey LilRed did you look your APC's over real well? I went with APC's on my old chevy for tail lights, parking and side markers, but I got tired of the not so perfect fit and apparent low quality. APC should stand for All Parts'r Crap! The tail lights never fit right and had a large gap between the bed and the light that I could never get to go away no matter what I did. One of the parking lights fogged up sometimes and took as long as 3 days to go away. The side markers fit decent but one of those fogged up too. I got some sweet projection headlights for it but by then I was sick of that APC junk and got a different brand that I can't remember the name of. And they were the worst of all the aftermarket lighting I put on! Never got them aimed right, I had to modify and cut up so much behind the grille. I finally got them to sit in the grille flush but like I said, never got proper aim. Thank goodness for auxillary lights. True they were for my chevy, and I have yet to buy any for my PSD. However I think that i'm going to get the 05+ head lights cuz I know they'll look good and should fit without or with minor modification. As for tails i'll buy some at a show, and install them there that way if they suck i'll take them back and try again....
Oh by the way Ebay is a great place to get parts from. |
Mine work very good. Fit and finsh are excellent. Cant really get my aim exactly where I want it but when the front is jacked up 4 inches higher than the rear its kinda hard to get them excatly where you want, you know. But anyway I love 'em kinda sets minie apart from the other ALL RED trucks as if it was unique enough
Well perhaps they have come a little ways as it's been two years since I got my lighting in the old truck. Plus they're completely different lights for the ford. Maybe I just got the bad luck bunch?
I got my headlights and corner lights (diamond style) from www.stylinconcepts.com in the lighting section. Just type in your year and model and they will show you what is available. I like the look and design of them. They fit right in with no modifications that I have heard with other companies. The lights that I got were made by IPCW. They are much brighter than the factory lights as well. I also got the clear cab lights from them as well. I think it looks good.
ebay
you can get them out of lmc truck but there expensive about 200 bucks or you can find them on ebay once and a while for around $30
