looking for 2 inch lift pics - Ford Powerstroke Diesel Forum
Old 12-09-2012, 08:45 AM
anybody have any photos of a obs with a 2 inch lift kit, dont want to go to high just a little, thanks
Old 12-15-2012, 12:43 PM
Here is my 1997 ccsb. Knucklehead son at the wheel. It has a 2.5 inch Tuff Country lift with 285/75/16 B.F. Goodrich tires. The overall lift with larger tires put it at just under 3 inches but there has been some settleing of the springs.
Old 12-28-2012, 06:55 PM
do you know if allignment is required if im just doing a leveling kit?thanks
Old 12-28-2012, 07:01 PM
Yes, if you lift/level you will need an alignment. I put a 2.5" leveling kit on my 97, made it look much better.
Old 12-28-2012, 08:39 PM
TTB w 2" body lift
Old 12-29-2012, 04:31 PM
okay just got done putting it on, need's allignment for sure but will allignment even fix this? or am i better off taking it back out and waiting for a dana 60 thanks
Old 12-29-2012, 06:19 PM
That's what mine looked like. Drive slow, bumps are scary with it out of alignment that bad!
Old 12-29-2012, 07:02 PM
should they be able to adjust the camber's that much? i dont really know much about them
Old 12-29-2012, 07:13 PM
That looks great! Did yours use drop brackets at the pivot points?
sent from a smoke signal...that I took a picture of with my S3..then translated to english words.
Old 12-29-2012, 07:42 PM
It MAY be able to aligned. OR it may need the drop brackets. Only time will tell. Also, you will want to get it aligned AGAIN a month later to compensate for the add-a-leaf setting in
