Wheel offset and backspace help?? - Ford Powerstroke Diesel Forum
Old 10-10-2012, 04:29 PM
Ok I have been reading about this all night and can't get a definative answer. I'm looking at wheel and tire size for a 97 F250 with a 4.5 RSK lift.
I'm thinking 35x12.5 tires would fit best. Now the wheels are a different story. I would like to stay in the 17" wheel diameter but options are limited. If I go 18s they price starts to jump quite a bit on tires and wheels... So maybe 16s but worry about the look. I was thinking about going with MT Classic with bead locks to keep a somewhat era correct look with a modern feel. They have them in 17x9 with and offset of "0" I would like them to sit about an inch or 2 past the wheel well. Now they also offer a 16x10 with a -12 offset so that should push the wheel out a little more. Any thoughts?
Also what kind of backspace do I need on this truck. I really never worried about this On past builds so I'm a little lost?
Thanks for the help guys and sorry for the new guy question.
Old 10-11-2012, 08:37 AM
Feedback Score: 5 reviews
Offset doesn't matter...4.5" BS is what you need, closer to 5" and tires will rub springs.
Old 10-11-2012, 03:33 PM
4.5" of lift is A LOT for a 35" tire.
Here is 2.25" of lift and 35s on white/blue
3" lift w35s on silver/maroon
Old 10-11-2012, 03:44 PM
So what do you think I should do?
Old 10-11-2012, 03:58 PM
Are those 35x12 on the blue and white one. They look wide. How do you like the pro comp tires?
Old 10-11-2012, 04:25 PM
325/65/18s= 34.8 x 13.3 on 18 x 10 wheels They are Micky Thompson ATZ. I am happy with them so far only have 5k on them
Old 10-11-2012, 10:42 PM
Here is my 95 on 35's Toyo MT's with 17x9 Procomp's with the Sky kit I got from Cary on new SD springs. It's supposed to be a 4" lift but I think it's closer to 5".
Old 10-12-2012, 02:53 AM
Looks good. That looks like a pretty good fit.
Old 10-12-2012, 04:48 AM
Are you including the d60 swap into the lift as well? Because that will give you 2" right there
I gained a total of 5" of lift when I did my D60 swap AND 3" RSK
Old 10-12-2012, 04:53 AM
The one I just bought has a D60 swap.
I am all kinds of confused on this lift tire combo haha
