dual exaust - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-25-2012, 10:42 AM Thread Starter
HOYBOY's Avatar
dual exaust
im looking to do dual exaust not stacks ive seen some on the superdutys but wanna know what they would look like on the old school powerstrokes
HOYBOY is offline
post #2 of 12 Old 05-29-2012, 07:25 AM
superduty4x4's Avatar
I can get you a pic later, I don't think I have any good ones right now except on my cell phone.
Diamond Eye makes the only kit available for the OBS and the install can be a bit of a beotch, just FYI.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 12 Old 05-29-2012, 07:30 AM
El Camino Man's Avatar
Not to threadjack but I always thought it was impossible to do a "true dual" exhaust on a diesel because of the turbo?
2011 Ranger 4x4, 4.0L
Custom LEDs
Camo Interior
1980 El Camino 5.0L, 200-4R
My Pride and Joy
El Camino Man is offline
post #4 of 12 Old 05-29-2012, 09:55 AM
chevy joe's Avatar
ive got duals on mine but its a dually and they come out right behind the dually fenders so you cant see both at the same time. i love them
1994.5 F-350 2 wheel drive 7.3 powerstroke, ZF5, crew cab, dually, rear air lift with dash gauge and controls, 5th wheel and gooseneck brackets in bed, alcoa's, and a ton of miles (over *474k* and going strong) *now with diy tymar intake, mbrp 3" downpipe to 3" duals, stancor relay, prosport boost and pyro gauges, single mass flywheel*
chevy joe is offline
post #5 of 12 Old 05-29-2012, 10:21 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I knew someone would say it..... we are just refering to dual exit exhaust.
And that isnt true that diesels can have "ture duals" as if u run parallel twin turbos u can have dual exhaust
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 12 Old 05-29-2012, 12:06 PM
Ahh gotcha. So basically youd have to have seperated twin turbos. Or a non turbo lol
Custom LEDs
Camo Interior
My Pride and Joy
post #7 of 12 Old 05-29-2012, 01:23 PM
ol_Blue97's Avatar
yup....
FRANK THE TANK
post #8 of 12 Old 05-30-2012, 06:38 AM
The diamond eye kit comes very complete unlike some other brands that say they are complete and you can find a good deal on ebay for duals. But as said before its a pain i have duals on my 96 and i helped a buddy put a set on his 12v. they dont sit very even so i had a new tail pipe bent for the drivers side to make it look right. I dont know if anyone else had this problem but the pipes that connect to the y-pipe and go over the axle were not bent that well for me it pointed my drivers side tail pipe up 15 degrees, even after getting a pipe made to get the pipes to look even and come out at the same angle the drivers side pipe is to close to the leaf spring so i still have some cutting and rewelding to do on the exhaust to make it the way it should have been made the first time, lol
good luck
96 F-250 ext. cab long box 4x4
Intake, auto meter(oil psi, tranny,boost, EGT) IDM mod, .030 over rebuilt motor, comp 910's, BDP d66 turbo, BDP stage one injectors, BDP fuel system, t500, BDP custom tuned 6pos, coolingmist water/meth, 3in downpipe 4in duals, dana 60 swap, 203* t-stat
traction bars, 6.0 intercooler
furture plans,
BTS, 300/200 sticks, studs, pushrods, t4 mount, NEW PAINT
GOAL= 600+ hp
stroked out is offline
post #9 of 12 Old 05-30-2012, 07:39 AM
good luck
I spent FOREVER tweaking the angles on the pipes to get them to come out the way they should. What bugs me more than anything is not being able to run the spare tire in the stock location... still hoping to find a way around that.
post #10 of 12 Old 06-28-2014, 04:16 AM
pk64f100's Avatar
95 exhaust needed
I need to replace exhaust in my 95 CCLB and also find a spare tire. I was thinking about dual exhaust love the way they look and sound but I am find with a single if all these issues exist trying to make it look right. Has anyone made a new kit that looks / works out better since 2012 when this was posted? Thanks
pk64f100 is offline
