front bumper adjustment - Ford Powerstroke Diesel Forum
Old 05-21-2012, 07:41 PM
Question front bumper adjustment
Any insight or advice before i start this? I wouldn't think its going to be difficult but from my quick look. It looks like this bumper is mounted different than i thought it was going to be.
Basically the bottom is sagging. 90% of the OBS rigs i looked at sagged. Hopefully an ez fix. My OCD Is getting to me about it. Mainly wondering if there is an adjustment or will i need to shim it?
Thanks
vandy
Old 05-22-2012, 05:15 AM
yep shim it! i used a few flat washers behind the upper bolts.
Old 11-24-2012, 02:02 PM
if you shim it the bottom of the bumper will come closer to the tire right? I just bought new tires for my OBS and they are 285, as of right now my bumper is less then a 1/2 inch from the tire when i am turned to the left. my bumper looks a lot like yours did in the picture. If i shim it will it for sure rub then?
Old 11-24-2012, 05:45 PM
If the blue truck in your sig is the bumper you are referring to, it is BENT or the brackets are bent. Take it off and straighten it
