How to: SD Fogs in stock bumper - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-12-2012, 10:54 PM Thread Starter
Gertrude's Avatar
Send a message via Skype™ to Gertrude
ok guys as requested i'm making a quick how to,
price list:
-smoked projector SD fog lights on ebay from p.s.team $68 shipped
-smoked cab lights on ebay from p.s.team $46 shipped
-smoked h/l's on ebay from IpexMotoring $130 shipped
-55w 10k hi/lo beam hids for h/l's from ddmtuning $60 shipped
-35w 10k lo beam only hids for f/l's from ddmtuning $30 shipped
overall install took about 2 hrs, i took my time and had to make two trips to Royal king for varying length 3/8" bolts
the fogs lights are projector fog lights with smoked lenses with halos
first you need to remove the four bolts that hold the bumper on located inside the frame rails at the front
then you will need to trim the tabs off the top and cut about half an inch off the bottom tab
just to clarify why you need to trim, the brackets clearly don't fit
*note the bumper is upside-down, the two tabs should be installed pointing up, also the word "up" with an arrow is pressed in to the plastic
here are the fogs mounted with the brackets mounted on the outside like the pic above
the projectors, since they have a cutoff at the top they can't be mounted deep in the bumper so i used a lot of 3/4" washers to shim the fog lights closer to the edge of the bumper
here it is with the lights shimmed out now, it pushed the lights roughly an inch and a half forward, the reason why i did this, the fog lights for best visibility need to mounted as far forward as in the bumper as possible
here is what it should look like from the back
*note these are the factory holes, and i just drilled through the plastic and wiggled a bolt threw
and here they are installed
just a quick before and after because i can
before
after
with 55w Bi-Xenon h/l's and 35w single xenon fog lights
I'm thinkin about adding another pair since there is enough room in the holes in the bumper, however the bumper brackets need to be notched to clear the projector housing, if i go this route (later, rather than sooner) i'll update as necessary
enjoy guys,
Andy
Andy=23
Future Mods: Project Revive/Rebuild/Restore
Too many cars, not enough money.
Gertrude is offline
post #2 of 8 Old 05-13-2012, 05:59 AM
elrojo63's Avatar
I like that. Might need to add that to mine. centurion package came with fog lights but they looked ugly so I took them out.
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #3 of 8 Old 05-13-2012, 07:53 AM
mjonesjr's Avatar
They look like they are pointing upwards in the bumper. Is there any adjustment in the light itself or does it have to be done with the bracket.
1997 F-250HD Extended Cab 4x4 7.3 Powerstroke
3" Down Pipe to 4" Exhaust (Stainless) ~ Tymar Intake w/ AFE Big Boost Filter ~ TS 6 Position Chip ~ HPOP Cross Over Line ~ Regulated Return ~ E-Fuel System ~ Intercooled ~ CCV Mod ~ Dual Aeroforce Interceptor Gauges ~ Dana 60 Swap
mjonesjr is offline
post #4 of 8 Old 05-13-2012, 08:20 AM
97Beast's Avatar
Quoted: 13 Post(s)
Nice writeup. Thanks!
I definitely want to add some now.
John
'97-F-250 PSD CCSB 3.55s E40D, Dana 60, PMF 2.25" RSK, U Code SD Springs, 315/75/16 TerraGrapplers, Tow Mirrors, Colibert Tow hooks, RDS Stage 1s, PHP 80hp, RiffRaff 6637, 3"DP, 4" Exhaust, 6" Tip, Power Front Seats, Rear 40/20/40, Explorer OHC and Autolamp Rearview, EATC, Cree LEDs & more
'89-Bronco 5.0l 33"s Free flowing exhaust, 06 SD power seats, & more (SOLD)
'80-M35A2 "Deuce 'n a Half" W/winch Multifuel Soft top
97Beast is offline
post #5 of 8 Old 05-13-2012, 04:55 PM Thread Starter
Gertrude's Avatar
thanks
they were in some pics b/c i hadn't tightened them down yet, but you can adjust the projector itself so its all good and also add shims (washers) to the bracket to adjust it as well
for example you can take some shims out of the bottom and add them to the top etc, you can also bend the bumper a lil bit too
thanks, it helps but i put too dark of an hid in there and my truck is lifted so it kinda helps with the lighting, that why im thinkin about adding another set
Andy=23
Gertrude is offline
post #6 of 8 Old 06-01-2012, 06:36 PM
UNDERCOVER_73's Avatar
Dude pleas paint those rims black lol. nice write up!
-06 F250 SCSB 6.0 191k
TSD Super Panty Dropper
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
Studded and Deleted.
50" Led Light Bar
4" lift 37x14s
-04 Crown Vic P71 interceptor 160k
UNDERCOVER_73 is offline
post #7 of 8 Old 06-02-2012, 09:45 PM
Were the aftermarket cab lights a direct replacement for the factory ones?
OKstang77 is offline
post #8 of 8 Old 06-03-2012, 06:11 PM Thread Starter
Gertrude's Avatar
thnx, yea yea yea i hear u , ill do them next week
idk to be honest, truck didn't have cab lights, i took measurements off a SD and kris (351fifty) said they are dodge styled cab lights
Andy=23
Gertrude is offline
