lift/level? - Ford Powerstroke Diesel Forum
Old 03-18-2012, 02:53 PM
lift/level?
OK guys, what would be the best way to do this (i know nuthing about lift/level kits, there looks to be alot out there.)
I want to go 2" higher in the back, and 3.5-4" higher in the front. that would level my truck out and get it slightly higher. Any suggestions?
Old 03-18-2012, 03:58 PM
You best bet would be to do the Dana 60 swap with a RSK.
Old 03-18-2012, 04:17 PM
i want to lift/leval, not swap stuff out to make it look how i want.
Old 03-18-2012, 04:19 PM
The only way to get 3-4" of lift in the front of an F-250 is to swap in a lift, not recommended, or do the Dana 60 swap with F-350 leafs and an add-a-leaf.
Those are you only 2 options. You can't simply swap 3-4" springs in the front of a TTB suspension and make it work.
Old 03-18-2012, 04:37 PM
Just do a skyjacker 4" kit. Has all the drop barckets and springs you need. The 4" kit will do everything you want
Old 03-18-2012, 05:09 PM
thanks digicam_obs il look into it
Old 03-18-2012, 06:08 PM
Ya! A buddy of mine just did a 4" skyjacker to his 96 f250 ccsb. Looks, steers and ride great!
