| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
D60 help
I know there are hundreds of threads of dana 60 questions, but i didnt want to read through all of them
I have a 97 f250 4x4 7.3 and i found a 97 f350 4x4 460 online for $700. It has the same gear ratio, and i know ill need the steering linkage. My only question is the springs. would it be best to get springs from one with the 7.3? I would like to do a 4in lift. Any help would be much appreciated!!
if you are just swapping it get the 350 springs, the 250 springs will work, but are stiffer than the 350. if you want a lift go with a RSK and super duty springs.
the springs are not the same from 460 to diesel, so your gonna wanna get super duty leafs with an rsk, or diesel springs from an obs
When i Did the swap in my 97 , My axle and springs came out of a 89 crew cab long bed with a 351. they made my reg. cab sit 3/4 of and inch higher in the front, than the st**** 250 rear height. It lifted the front 3 inches over stock.
What years SD should i look for? and will it make a difference if its a 250 or 350?
for springs? i would talk to cary at ctperformance he is a vendor here. people talk about b codes and v codes. b and v have to do with part numbers, but it's all over my head i never looked into that
| Tags |
| d60, dana 60 |
