Dual tanks? - Ford Powerstroke Diesel Forum
Old 04-09-2011, 09:07 PM
Dual tanks?
THis is a newb question so be gentle. Just bought my first diesel (96 4x4 f250 crew, short bed). It has dual tanks. I see the switch. When and how should I switch fuel tanks? Can I switch them while driving or should I stop? Should I switch when I am 1/4 full .. 1/8 full ... does it even matter?
Old 04-09-2011, 09:15 PM
U can switch them while u drive but I would not run it too low I would say no less the 1/8th tank when u switch cuz if u run out befor switching u will be on the side of the road and its bad on the injectors fuel pump ect..
Sent from my Ally using AutoGuide App
Old 04-09-2011, 09:17 PM
switch when driving's ok, your choice when to switch, i don't let mine go below 1/4
Old 04-10-2011, 10:25 AM
Hey thanks, for the replies.
I remember as a kid on a lawn crew the crew chief was driving a truck with dual tanks an he switched while driving, but I couldn't remember. Been a long time since I was a kid.
Any idea how big the tanks are on a 96 f-250 crew 4x4 short bed?
Old 04-10-2011, 10:32 AM
Electrical Ogre
Specs show 34.7 gal capacity. Probably a 17 gal front tank and a 18 gal rear tank.
Old 04-13-2011, 08:21 PM
yes all these guys are right and donīt forget donīt let down under 1/4 of tank bīcos you will damage the tandem pump ! and injector bīcos them suck air into the fuel lines !! mine is a crew cab long bed dually with dual tanks
Old 04-14-2011, 04:01 AM
Hey great, y'all. I appreciate the answers. Learning little by little here. Glad I found the forums.
Old 04-14-2011, 08:30 AM
well supousing you ford truck are long bed and 95 up it have a 75 liters tanks so are 150 liter both same as me !! keep you ford rolling !!!
