Shackle Flip - Ford Powerstroke Diesel Forum
Old 03-29-2011, 10:10 PM
Shackle Flip
Has anyone ever done a Shackle flip on a 1996 F 350 ? What type of lift did you get afterwards and what size tires where you able to use afterwards ?
Thanks
Old 03-30-2011, 12:49 PM
Definitely been done. Might even be a writeup in the mod section. Supposedly it gives 2-3" to fix rear-end sag. Not sure on tire size though!
Old 03-30-2011, 03:34 PM
Feedback Score: 5 reviews
Not what I would recomened..how high are you wanting to go?
Old 03-30-2011, 05:54 PM
Shade tree mechanic
Yeah theres a write up somewhere around here for an OBS. IIRC its somewhere in the neighborhood of gaining 2".
Old 03-30-2011, 05:57 PM
Keep in mind that doing a shackle flip will move the axle forward about .5"!
Old 03-30-2011, 08:13 PM
Hey Cary
If Possible I want to do a 6 inch suspension and then the shackle flip on top of that for I am hoping about 8-9 inches of lift. I want to put 42 or 44 inch Iroks as well if they fit.
Old 03-31-2011, 11:40 AM
Shackle flip is 4.5" and as Trevor said will shift the axle forward. Gona need lots more than 8-9" of lift for those tires unless you are using std lift springs that won't move at all. Or cut out flares..
