| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
315/75/16 on f350 stock height will they fit?
Looking to put some 315/75/16 on my 97 f350 with stock height. Wondering if you guys have any pictures. And do I need to mod anything to make them fit. Thanks in advance.
I have a 97 F250 with an add-a-leaf up front and couldn't fit 325/60/18s which are a little over 33 inches tall...the corners just barley rubbed the bumper as i turned otherwise cleared...but the 315s you are looking at would be over 34 inches...i would guess they wouldn't fit without shaving the bumper...
OK Thanks just seems like I have a lot of room under there with my 285/75/16"s
maybe being a little narrower it might fit...but its only 1 cm...so i wouldn't think it would fit...know any buddy's that have them? thats how i found out the 325s didn't fit
No. I wish. All my friends run 285's also
I'm looking for a set of 285s I have a second set of rims for this summer i would like to put a cheap set of rubber on but haven't found any yet...
my h2 tires and wheels fit just fine on my stock 1996 f350. with 282k on the stock worn out springs. I have a warn enforcer bumper up front maybe that helps?
You can try spacing the bumper out or get a RS kit..add SD springs and kill both your problems..clearance and ride quality
![]() Here is a pic of 315's with no lift and on 10" rims. All that is under it is a D60 with stock F350 springs - the only problem you may run into is the bumper. some trimming would take care of it though. That is the largest tire I can fit under there but I don't rub at all. |
36x12.5x16.5 wranglers on 10 wide rims. spaced out the bumper about 1" and there was no rubbing at all
http://s582.photobucket.com/albums/s...t=DSC01723.jpg
