smoked clearance lights - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-18-2011, 06:09 PM Thread Starter
does anybody know were i can find smoked clearance lights or how does the vht tint spray look over the amber
waytofast79 is offline
post #2 of 6 Old 01-21-2011, 09:05 AM
You can't find the stock lights in smoked.
I'll let you know how vht looks on the amber lenses in a week or so. I just picked up some LEDs that I hope fit the OEM light housing.
I am still unsure what to do with the white base of the clearance lights. Whether to do gloss black, try and match the stock dark green of my truck, use vht on it and do the same process with the base as the lenses? Ideas would be great.
I do know with vht if you want it to be glossy you have to spray clear gloss over the vht.
1995 f-350, 108,000 miles and climbing, second motor with approximately 130,000 miles on it.
DIY Intake, stage 2 injectors from Rosewood, 3" DP to 5"side dump with a 6" Tip
HPOP, 6.0 IC (anyone have a spyder?) and E fuel to come
wakeboardin2k4 is offline
post #3 of 6 Old 01-22-2011, 03:41 AM Thread Starter
ok cool let me know
post #4 of 6 Old 01-22-2011, 05:42 AM
2wd_sled_puller_dmax's Avatar
VHT works my clearnace lights are smoked i smoked them myself turned out really awesome. Just remember to shade it not cover it. it will take probley 2 coats
97 dodge 3500 flat bed 4x4 5x16 injectors 66 mm turbo dtt automatic
2000 Dodge 2500 2x4 all stock other then dtt tranny
2wd_sled_puller_dmax is offline
post #5 of 6 Old 01-22-2011, 05:58 AM
smith7.3's Avatar
what yr truck? i got mine from ebay.
2002 F250 Lariat Crew Cab 4x4
zoodad
DIY P2818 filter
elc
straight pipe
Gauges -Boost- Tranny Temp - EGT
PHP tunes
smith7.3 is offline
post #6 of 6 Old 01-22-2011, 06:37 AM
I was under the impression that a certain generation of dodges have a good cab light for the obs. Recon sells em smoked
Originally Posted by 96cobra10101
People never fail to disapoint. I hope he/she gets a$$ raped by 100 gay giants.
2003 Extended cab Short box- 7.3 of course
Rollin on 35's
Mods:
-Diy intake
-Tw tunes
-Autometer Guages
Coming soon:
-Foil delete with painted pipes
-6.0 intercooler
-Water/Meth injection
PROJECT-Late 1994 powerstroke gettin a 12v
bauer is offline
