| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
clearence light wiring.
I was wondering if anybody know's the parts number or where to get a oem wiring harness for the clearence lights. The local ford dealer coulfn't find anything. Thanks
I got a set from Pacer...they just send wire and the 3m connectors...all ya need to do is pull the light switch out of the dash and there is a place to plug a spade into it for the clearance lights if I remember correctly. The lights came w/ about 12 ft of wire...you shouldn't need a harness...my lights grounded w/ the screws that hold them on also...so you should only need one wire.
thanks for the info, that sound pretty easy.
it is pretty simple, the hardest part is bringing yourself to drilling 15 holes in the roof your pickup, and make sure to use lots of silicone, don't want any leaks...if ya need measurements or anything let me know
i found the part s# for obs wiring harness- F2TZ-15A404-AA from the local dealer for $50. I think $15 for wire,connectors and some screws is the better way to go.
