Cab/Clearance Light Help - Ford Powerstroke Diesel Forum
Old 11-22-2010, 09:33 AM
So i have seen a couple threads on here of people installing cab lights. I am actually looking into getting these cab lights because i think they look better than the HUGE bulky OBS Ford ones.
Recon Accessories: Part # 264146BK - SMOKED Cab Lights Dodge 03-11
Amazon.com: Recon 264146BK Smoked Cab Roof Lights 2003-2007 Dodge Heavy-Duty 2500 & 3500 (5-Piece Set): Automotive Amazon.com: Recon 264146BK Smoked Cab Roof Lights 2003-2007 Dodge Heavy-Duty 2500 & 3500 (5-Piece Set): Automotive
1. I was wondering if anyone had a layout for where to place the lights.
2. How would i wire the lights if my truck didnt come with cab lights from the factory? (im not that knowlege able in electircal stuff)
Any help would be REALLY appreciated!
Thank you
Old 11-23-2010, 08:52 AM
I set mine on the roof where they looked good, measured and to my surprise, they were actually quite close. I went to the junkyard and got the factory harness, ran it up the pillar and into the roof like factory and plugged it into the factory connector behind the passenger side kick panel
Old 11-23-2010, 07:14 PM
Are these dodge ones plug and play with the originals?
Old 11-23-2010, 09:00 PM
thats what i was questioning...i think i am gonna just call Recon and see what they suggest. Probably would be the easiest thing to start with!
Old 11-24-2010, 06:55 PM
If they dont you can get the correct connector and connect or just cut the connector off the factory end and connect them.
Old 11-24-2010, 09:38 PM
Cab Light Install
Here is a great link that I used to install my OEM Cab Lights. Motoman's Madness
He goes into great detail on lay-out, and on wiring. It was much easier buying the factory wiring harness, and the truck already has a cab light harness that you just plug into. I hope yours go as smooth as mine.
