Does it have a LSD's? - Ford Powerstroke Diesel Forum
Old 09-13-2010, 10:28 AM
How do I tell if my '95 f250 4x4 7.3 PSD turbo supercab has LSD's ?
Thanks,
~Zechariah
Old 09-13-2010, 10:31 AM
whats the axle code on the door tag say? if it has a letter in it, its a limited slip
Old 09-13-2010, 10:51 AM
This is totally unrelated and I've wanted to ask this for a long time and bare with me here but on obs F-350 duallys was there any way to get 4x4 from the factory or you just had to convert a 4x4 250 to a dually?
Old 09-13-2010, 10:55 AM
no 4x4 f350 obs duallys from the factory.
Old 09-13-2010, 11:12 AM
There should be a tag on the rear differential cover. It will tell you what gear ratio it has and if it is a limited slip or not. if its a limited slip it will either say 3.L55 or 4.L10. If it has an L in it, its a factory 2 pinion "trac-lok". I snatched up a 3 pinion factor trac-lok out of a 99+ superduty from a guy I used to work with for $50. all it needed was a side bearing (which i used off the open diff. that came outta my truck). Works just fine. I went with the 3 pinion because its a 2 piece case. I unbolted it and shimmed up the clutches to make sure it was plenty tight. hope this helps.
Old 09-13-2010, 12:39 PM
It says on the tag on the door "Axle 35 Type P" what does that mean?
Old 09-13-2010, 01:01 PM
not really sure about the door tag, I've always looked on the diff. tag. You should be able to ask the parts department at your local ford dealer. they should be able to give you an answer.
