ttb lift kit options - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-31-2010, 09:58 PM Thread Starter
bishopwashere's Avatar
i need help finding lift kits for my 1996 f250 ttb or ideas on how to build your own watever is cheapest but as of right now i do not need 4x4 or want to do a d60 swap... so any information would be appriciated thankyou jimmy
bishopwashere is offline
post #2 of 3 Old 09-01-2010, 01:05 PM
lugnut1009's Avatar
Quoted: 8 Post(s)
Ok, sounds like you've got a 2wd? Might want to give a little more info.
But, those of us with TTB front ends (2 or 4wd) are pretty much screwed when it comes to lifts. It's either spend a bunch of money on lifting it or spend another bunch of money on a D60. If you're only looking at leveling it, you could probably find a lift for not too terribly much with just camber bushings and a add-a-leaf or something. Haven't looked though.
SOLD (AND SORELY MISSED):1996 F250 CC SB ZF5 4WD
9000LB Ramsey winch, 3" dp, straight exhaust, superchips mini max, 6637 filter,
4" Superlift, 315/75 Toyo MT's, custom step bars
2011 F150 CC 2wd with V6 Eco-boost
factory twin turbo and intercooler, 365 hp and 420 ft/lb torque
lugnut1009 is offline
post #3 of 3 Old 09-01-2010, 04:49 PM Thread Starter
right sorry well its a 2wd and i have coil springs and would like to buy or make a lift but no springs will hold the diesel motor for the kits ive seen sold for a f150 or bronco so any other ideas like newer style superduty lift springs?
