What Size Tires Will Fit My 96 F350 With A 4" Lift? - Ford Powerstroke Diesel Forum
Old 05-15-2007, 01:27 PM
Does Anybody Know What Size Tires I Can Fit On My 1996 F350 Crew Cab Psd With A 4" Suspension Lift?
Old 05-15-2007, 11:01 PM
33" or maybee 35"
Old 05-16-2007, 02:40 AM
I have 33's without the lift right now and they don't rub at all. Is it possible that 37"s will fit?
Old 05-16-2007, 03:05 AM
Rob Rob is offline
with a 4'' maybe, i have a 6'' with 37's and they fit fine. i would say 35's would look better though if you are going with a 4'', JMO.
Old 05-16-2007, 06:50 AM
35's will fit on a stock f-350 with a leveling kit so with the 4" lift you mite be able to squeeze 37's..
Old 05-16-2007, 06:52 AM
you will def have some minor rubbing... but nothing some trimming wont fix.... but i think 35's would look better
Old 05-23-2007, 03:08 AM
Thanks for the quick reponces.
Old 05-24-2007, 10:11 AM
I run 315's on stock suspension and I don't have any fitment issues. I've seen 4" OBS F350's locally that run 36" tires. I'd say 35 is the MINIMUM that you'd want to run.
Old 05-24-2007, 03:23 PM
I have a 4" with 315/75R16's. They rub the left leaf springs on a hard left turn(stock wheels) but other than that there are no issues. I'm looking to go with some 36-37's.
Old 06-01-2007, 11:45 AM
I put 36"X12.5X16.5" tires and rims on my stock truck without any lift and they do not rub at all!! I read that a 4" lift was needed for this but said screw it and gave it a shut in the dark by using guess and check. This time was i my favor!!
