Easiest Way To Remove Door - Ford Powerstroke Diesel Forum
Old 06-11-2010, 01:57 PM
Whats best way to remove door with pw pl??????
Old 06-12-2010, 03:50 PM
sawzall baby or a tourch or take a nother truck and open the door and run into it at 50 oooohhhhhh yyyeeaaaaa baby do what it do
Old 06-21-2010, 08:36 PM
Take off the kick panel and there is like 3 or 4 plugs running vertical in the kick panel. Disconnect the plugs there. Thats where all the wiring feeds to the door...
Work the rubber conduit out of the A pillar on the truck, and pull the wires through the hole.
Remove the four bolts that hold the hinge to the door
Old 06-22-2010, 04:04 AM
What is the kick panel exactly????
Old 06-22-2010, 05:46 AM
Its the plastic trim panel by where your feet go... below the dash, above the carpet on the wall of the cab... Its where the hood release is.
Old 08-14-2010, 01:02 PM
I'm trying to do the same thing and I found one of the connectors behind the kick pannel but there is another set of wires that goes up and I can't find the connector for those wires and I don't want to take apart my emergency brake mount to get to them. Is there another way to get to those wires?
Old 08-14-2010, 08:27 PM
Electrical Ogre
The drivers door harness has one connector by the emergency brake, the other one goes allll the way to the passenger side kick panel. Yes, it is a dumb idea Ford had. You're probably better off to remove the switches from the harness and unplug everything in the door and remove the wiring from the door.
