| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
hey guys i just got the ciltons maunal for my truck ( 93 f350 ) and i saw in there that ford had a straight axle setup in the front of some 2wd trucks.. its like a small i beam that runs the whole distance between the tires. not the small IFS i beams i have.
wondering if anyone has seen this and maybe if there was one laying around i could buy everything from to do a BIG lift to my pickup.. its either this or i can fab up some new coil mounts for the front of my pickup but if i fab i can only raise 6 inches.. ideally i would like a 8-10 inch lift PLUS my tires and 3 inch body.. i wanna get WAY up there. so i guess im asking if anyone has seen/used this setup before and how it was. also if anyone know of them laying around somewhere maybe i could get the contact info to pick it up ![]() thanks guys
That would be an OBS superduty or F-450, check the salvage yard Ford made them from 88- 97.
so all SUPER dutys from 88-97 share this front end?
and all the hangers and stuff should work on mine? GREAT INFO THANKS!! |
also should i buy a lift for a superduty then??
or will any 4wd lift with the 4 leafs work?? is there a difference? |
YES and NO! an F-450 or old body style Superduty is a 14,500# comercial cab & chassis, with 10 hole wheels.
88-97 F-250/350s are not Superdutys. |
so i would need a rearend out of one of those too correct?
**** basically i need to find the whole truck and swap out teh suspenions then.. anything else different on them? drivesahft and my exhaust will work?? leafs will bolt on? etc? Last edited by 04mach1; 05-03-2007 at 08:37 AM. |
Yes, you could swap the whole suspension but they ride like an Iron Wheeled Wagon!
not too worried about the ride.. im sure mine isnt much better!
do i need a lift SPECIFICALLY for the super duty?? or can i buy an ordinary one for a 4wd f350 setup?? after i get this info. i think i can make a educated guess on the cost over functionality equation... i just wanna leave my doors open to different ways to lift it up.. not go one way and once complete say OH MAN!!! i wish i would have done the other way! |
an F-350 rides like a towncar compared to a F-450
as far as lifts I cant help much with that. |
will a newer style trucks leaf spring bolt on the rear of my truck??
they make 10 inch lift LEAFS for the rear of the new style truck.. then i could make my own lift for the front. anyone know? |
