Wiring Issues?? - Ford Powerstroke Diesel Forum
Old 04-13-2010, 07:40 PM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
Wiring Issues??
Okay so i installed some new reverse lights because my old ones just flat sucked!
I got some nice ones off craigslist for $5 per light and so i bought a bunch of them. Well installed them using the old wiring, they currently had 24v bulbs in them (off a piece of construction equipment). They were super super dim with the 24v bulbs in (obviously).... and i tested to make sure i had power back there and everything and all was good...
Drove it a couple days until i could get to the store and buy new bulbs. switched them out for 100w h3 bulbs from bi-mart. Now i have NO power at all to the reverse lights, the stock ones in the brake light assembly don't work either now?? I tested the wire coming from the front of the truck to stock reverse light and there is no power. I am stumped, is there a fuse or something that goes to this?? The brake lights work perfect.
Old 04-13-2010, 07:45 PM
Sounds like you drew to much load and smoked a fuse.
Old 04-13-2010, 07:50 PM
yeah thats what i was thinking.... With a 24v bulb in there it could mess something up huh??
My next question is that a fused wire??? I am hoping it is and it didnt just melt the wire somewhere....
I can't find anything else thats not working?
Old 04-13-2010, 07:52 PM
Every light on a Super Duty is fused I don't know on the OBS though.
Old 04-13-2010, 07:54 PM
okay well hopefully someone that does know will chime in.... Otherwise these are getting wired to a switch or something....
ANYONE KNOW IF ITS FUSED? I'd rather not check every fuse everywhere
Old 04-13-2010, 07:58 PM
When I had to rewire Raul's brand new trailer because the company that I told him was alright sucked I learned alot about the electrical system in these trucks.
Old 04-13-2010, 08:00 PM
well you should have done some OBS studyin while you were there
Old 04-13-2010, 08:01 PM
I am guessing it is fused. Everything electrical is fused.
Old 04-13-2010, 08:06 PM
Know of a place i can get a wiring diagram of the truck? So i can see if its fused and where it would be fused at
Old 04-13-2010, 08:07 PM
Electrical Ogre
Probably blew the fuse 5 in the underhood box, 15 Amp.
You'll need to run the extra lamps from a relay, otherwise you'll cook the wiring (or just keep poppin' fuses.)
