Stock 2001 wheels on a 1996 - Ford Powerstroke Diesel Forum
Old 04-27-2007, 07:10 PM
I have a 1996 single rear wheel F250. Will my dads 2001 stock alum. 16 inch wheels fit using his lug nuts?
I've read the post on the 1993 truck but no one said why or why not they will fit.
Thank you
Old 04-27-2007, 07:34 PM
The wheels from your dads 01 will not fit due to the bolt pattern. The OBS trucks are 8x6.5" while the SD trucks are 8x170mm. Sorry to burst your bubble. I went through the same thing...lol
By the way Matt, WELCOME to the forum.
Old 04-27-2007, 07:46 PM
Thanks, I wanted to use his wheels because the last time I rotated and balanced mine, I found one of my steel wheels is bent. The truck rides great but the wheel took 12 onces of weight on one side and 6 on the other. Thats
two times the weight it too kwhen the tire was first mounted.
Old 07-03-2007, 11:56 AM
I along with NOVAJOE105 went through the same thing with the SD wheels not fitting.
