Cheep way of lowering my dually? - Ford Powerstroke Diesel Forum
Old 04-23-2007, 04:10 PM
Send a message via AIM to ienjoydrifting
Id like a 4-5 inch drop front and rear.
In the rear I can just put the leafs on the bottom of the axle assembly and raise the bumpstops and shock mounts via welding.
But what about the front? What will I have to do to put it down?
I am assuming move the front shock mount, but what about the spring? Id rather not cut it, thats alittle to ghettoFAB for me.
Old 04-23-2007, 08:11 PM
How much drop in the front if you want 2" you can have a sprng manufacturer make a set of coils for you, If you want 3" buy lower I-beams get the belltech ones (part# BEL 4020), DJM suspension is cheaper but the belltechs are much stronger, and if you want 5" of drop ( the Maximum drop you can get on these trucks without extensive frame fab) combine the 3" and 2" method
If you tow alot of weight a flip kit will need to have airbag assist, you can get 4" from a hanger/shackle kit that belltech makes( part# BEL 6420) you can also remove a leaf or two on spring pack for about another 1"
Old 04-23-2007, 08:49 PM
The belltech beems do seem like the better setup.
