19.5's on a 97' F-superduty? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-09-2010, 08:15 AM Thread Starter
Hi,
I'm currently looking to purchase a 97 F-Superduty (F450) with the 16" 10 Lug rims
I am wondering if the 19.5s from the 04 + F450's would fit ie. same bolt pattern?
and will it affect the speedometer in any way? Its a manual so it wont mess up the tranny
ITRalex is offline
post #2 of 4 Old 02-09-2010, 03:30 PM
speeddemon31176's Avatar
Yes the 10 lug rims have the same bolt pattern. As long as the revolutions per mile remain the same then no your speedometer will not change. A good truck tire shop can tell you what size tire will have the same rpm as the 16" tires that are on it now.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes next.
speeddemon31176 is offline
post #3 of 4 Old 02-09-2010, 03:36 PM
Raging Lunatic
choctaw's Avatar
Check the backspacing...............
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #4 of 4 Old 03-07-2010, 09:47 PM Thread Starter
hmm, do you know if the center bore sizes are different?
i've been reading the forums and i've been getting answers from
10x184mm bolt pattern with a center bore of 5.46"
and
10x225mm bolt pattern with a center bore of 6.705"
ITRalex is offline
