SD cab lights on an OBS? - Ford Powerstroke Diesel Forum
Old 02-02-2010, 12:21 PM
I have been looking into puttin some cab/clearance lights on my 96 F-250 and haven't found too many options for OBS lights. There seems to be a lot more selection in SD lights and im wonderin how it'd look and if it'd work to put SD cab lights on my OBS. Anybody got pics? Also, i know the hardest part is drillin the holes for the lights and all, but where would i find a wiring harness for the lights? thanks in advance
Old 02-02-2010, 05:17 PM
Look at LMC Truck. They have OEM-style lights (either in standard or LED) for the OBS. I got the standard (non-LED) lights for my truck from them and they look great.
Old 02-02-2010, 05:37 PM
well I checked out the LMC ones and i like them, but i'm hoping to find a set of smoked/black lights and all they have are the clear or amber lights
Old 02-02-2010, 05:40 PM
Ah I didn't know you were looking for smoked or black. Have you checked out recon?
Also the wiring is real simple...you can either do what I did and ground the lights locally and run a hot wire down the drivers side pillar and into the back of the parking light fuse, or run by ford and get the harness/connector. There is a connector in the passenger kick panel specifically for the clearance lights.
Old 02-02-2010, 05:43 PM
My bad, forgot to mention that in the original post. haha. and yeah i checked recon but all i can find is SD
Old 02-02-2010, 05:44 PM
and good deal on the wiring, sounds easy enough
Ive seen the the SD cab lites on a OBS, they dont look to bad, but i still like the OEM OBS lites better, I saw a pic on google I'll try to find it...
