My #$*%@ hood latch broke!!!!! - Ford Powerstroke Diesel Forum
Old 12-21-2009, 09:50 AM
Yup snapped right off under the hood . Anyone have any ideas how to get it open. I was trying to feel around for the latch to release it but my fat hands make it hard.
Old 12-21-2009, 10:05 AM
I don't know if it will work on SD's but I know on rangers, if you have an extention and a socket, you can unbolt the latch right off the core support and open the hood.
Old 12-21-2009, 10:12 AM
I've got one of a superduty if you need it.
Old 12-21-2009, 10:38 AM
That happened on an old bronco I had and I was able to yank on the cable through the grille.
Old 12-21-2009, 02:26 PM
yea you can get it off this way you have to take the bolts holding the latch on to the center beam going up infront of the radiator.
Old 12-21-2009, 05:02 PM
It's on the 97 (were they SD's back then)work truck and I already have the cable because it broke off in the cab. Then while trying to pull on the cable other end went
I did see the bolts you are talking about.
Thanks for the help guys
