Largest tires I can fit on a stock OBS? - Ford Powerstroke Diesel Forum
Old 12-01-2009, 09:40 PM
I searched and looked for a bit, didn't come across a thread.
I'm going to be getting new tires soon. Was wondering what the largest ones I can fit on a stock OBS is? My truck currently has 265's if I remember right. And with those tires A lot of frame shows in the rear.
Was wondering if I could fit 285's/33's on my truck without any trimming or anything.
Thanks.
Old 12-01-2009, 09:47 PM
You can fit 285s on there easily.
Old 12-01-2009, 09:52 PM
Thanks for the quick response. I was somewhat concerned about having to trim the from bumper, but I guess that isn't an issue.
Old 12-01-2009, 09:57 PM
a truck
Biggest I could fit was a 285/75/16, I had to do a very minor trim on the bumper, but you could easily just space it out a little
Old 12-01-2009, 11:31 PM
Send a message via AIM to FiberglassEater
i had 37's but only had to trim an inch off the bumper..
Old 12-02-2009, 12:04 AM
a truck
yeah but yours is a 350, with that dana 60 under there your truck sits a lot higher stock compared to a 250.
Old 12-02-2009, 08:38 AM
Are sure those are 37's. they look more like 33's
Old 12-02-2009, 12:34 PM
my stock 2wd 350 fits 285s stock no lift no trim BUT they do rub on the sway bar when you try to turn to lock but i'm used to it my buddy has a 4wd 250 gasser w 315s and they don't rub and he didn't trim anything
Old 12-02-2009, 01:49 PM
mines rubs as well, im going back to stock when i get new shoes......
Old 12-02-2009, 02:30 PM
i have 315/75 M/T's on my stock f250 obs. they rub a little on the leaf spring
fyi; if you dont want to trim your bumper you can bump it out with some washers. their is only 4 bolts the hold it on there.
