Ok so when I bought my truck there was a little spot of rust right above the trim on the rear fender on the passenger side besides that clean as can be. Got it fixed twice, just had it grinder down and repainted but it came back each time, today I took the trim off and found all of it!!!! Also had it staring on the other side thinking it's just a little spot and Then i took the trim off and it was worse than I thought. Question is can this be cut out and repaired or is to late, and I'm better off just selling my truck at this point. Here are some images of it below
Passenger rear side:
Drivers rear side:
Sent from my iPad using Tapatalk
Drivers rear side:
