Extended cab long bed to 4 door flatbed - Ford Powerstroke Diesel Forum
Old 11-21-2009, 04:27 PM
Here's a couple pictures of what I've been working on for the last few weeks.
Pics quit working, check out my gallery.
Old 11-21-2009, 04:59 PM
Truck looks good!
Old 11-21-2009, 05:05 PM
looking good man
Old 11-21-2009, 09:39 PM
Thanks. I'm trying to decide whether or not I want to install my Lund visor. What do you think? As with most projects this one will never be 100% done, there's always some tweaking to be done.
Old 11-22-2009, 09:28 AM
did that cab bolt on pretty easy?
i have been thinking of converting my truck to a crew cab short box but was wondering how easy the body mounts would be on the cab.
Old 11-22-2009, 02:53 PM
I ended up doing a 2" body lift at the same time because the rear mount bushing is really thick and I'm a cheapass so I didn't want to buy new shorter ones. I welded a piece of 5" channel with most of one edge cut off (to clear the body) on top of the frame. I had to dent the front tank a bit for the end of the bolt and nut to clear. The front mounts bolt up normally.
Old 11-22-2009, 03:27 PM
do you have any pics?
just want to know what i am getting my self into before i decide if it is worth it or not.
do you think it can be done without the body lift?
i really don't want any more lift in my truck.
Old 11-25-2009, 12:58 PM
Here's a couple pics, I hope they help. I think if you were motivated enough and took your time you could get away without the body lift, or you could easily reduce it to only an inch or so of body lift. The swap wasn't really that difficult, the crappiest part was swapping the dash wiring, pedal assy and steering column (donor was a gas auto, mine's a PS 5 speed) EDIT: Did all the pictures in this thread stop working for you too?
Extended cab long bed to 4 door flatbed-steel-007.jpg   Extended cab long bed to 4 door flatbed-steel-008.jpg
Old 11-25-2009, 08:53 PM
the pics dont work
Old 11-27-2009, 03:10 AM
yeah the pics didnt work
