Roof rack. Need ideas. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-23-2016, 09:23 AM Thread Starter
Hi,
I want to build a roof rack for my CCLB obs.
I just need to figure out how to safely attach it to the top.
Do you guys have any pictures or ideas ?
Thanks!
crazy_canadian is offline
post #2 of 7 Old 03-23-2016, 09:28 AM
Heavy_GD's Avatar
Quoted: 1648 Post(s)
Feedback Score: 3 reviews
not a lot of people using those here.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #3 of 7 Old 03-23-2016, 09:30 AM
sbluke55's Avatar
Quoted: 588 Post(s)
Garage
You could always use a roof rack system like Thule or Yakima. Or make some feet and drill through the roof.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 7 Old 03-27-2016, 05:39 AM
Quoted: 5 Post(s)
I plan on making one like the desert chase trucks that actually mounts to the bed rails. I am not a fan of drilling holes in a perfectly good roof.
fiveohmatt is offline
post #5 of 7 Old 08-03-2016, 10:44 AM
TNT63's Avatar
Are you willing to drill holes in the door jamb behind the weather stripping? That's where I mounted my roof rack. I attached a picture of my truck with my roof rack installed.
2001 F350 CCSB 7.3 Powerstroke
Mild build
Irate T4 with S366
Rosewood Diesel Stage 2 160cc/80% single shots
Gearhead Stage 1 cam
Gearhead Custom tuning
Comp-Cam 910 valve springs with Smith Bros. pushrods
Fuel lab Regulated return with Fass Sump and custom pre and post filter setup for stock fuel pump with 3/8 fuel line from tank to motor
ARP head Studs and Main studs
Dynoproven Girdle
ATI Harmonic Balancer
Fully built 4r100
TNT63 is offline
post #6 of 7 Old 08-07-2016, 06:39 PM
ptp
ptp's Avatar
Quoted: 64 Post(s)
i'm using a Thule for the last 15 years, but it's cracked and kinda gimpy.
you can get the roof racks used on the VAN's that clamps onto the drip rail.
what they use to haul ladders etc. and are pretty beefy.
i've always wanted to have a sort of cab-over roof rack that attaches to my camper shell with flexible boot and "pass-through" to the front of camper shell.
ID:	556330   Click image for larger version
ptp is offline
post #7 of 7 Old 01-22-2017, 08:49 AM
Quoted: 5 Post(s)
I did this one and the light bar mounts
That1tileguy1982 is offline
