| 94-98 7.3L Exterior Discussion Body and Accessories Talk |
35s on a 2wd 93 crew cab???
hey guys looking at these wheels and tires.
wondering if they will fit? what do u think. again my truck is a 93 f350 2wd. thanks Weld Racing SuperSingle-II Aluminum Wheels (16x10; 8-lug on 6.5in.) wrapped with SuperSwamper 35x12.5R16LT Radial TSL tires. Center caps for 4x4 included. also will hte center caps work since i dont have 4wd? thanks |
Ok they should fit if you do a lift to your truck. The center caps will work but look kinda funny having a hole in the front center caps where the 4 wheel drive hub sticks out of the center cap. You should be able to use your stock center caps or order two for the rear to put on the front wheels. |
can i do a 3 inch body lift or do i have to pull a all out suspension lift?
becuase i cant find any kits for the 2wd ![]() how much of a lift do i need you think? i found a 3 inch body lift on ebay for like 120 or something. so i would like to do that while the box and stuff is already off. thanks! |
You might be able to get away with just a 3 inch body lift. Even though your truck is 2wd I don't recommend a body lift. You may want to check with Fab-Tech Suspension I believe they make a leveling kit or a 4 inch suspension lift for 2wd superduty's. They are not that hard to put in being your truck is 2wd so there is less work involved.
they make one for new superduties ya but not my old 93
I beg to differ, I just looked up a 93 F-250 2wd on the web site that I list below.
Lift Kit-Suspension w/Shock - Products |
sorry to be a prick BUT...
a direct copy of the listing on the site. For: 1993 FORD F-350 PICKUP Part Number: FABKIT268 4 in. Performance Kit with Performance Shocks; Rear Block and U-Bolt Kit; Alignment Cams; I Beam Drop Brackets; Extended Radius Arms; 460 V8 Only; Includes Performance Shocks; Kit Color is Classic Blue; this is for the f350 2wd 1993. i have the 7.3 diesel. not sure if it will matter but it says 460 GAS motor only ![]() will it go on? also will these kits affect the weight i can carry? whats the CONS to a body lift? i read someone mentioned NOT to do them.. thanks guys! |
Ok my fault, check superlift part number SUPK582 as it states for gas and standard diesel engines. 4 inch lift, as for your towing abilities shouldn't have much affect on your towing of loads. I prefer Super Lift over Fab Tech. But I know Fab Tech has alot of 2wd LIft kits. Plus the Superlift is better on price and from my experince better quality too.
awesome thanks!
ill check for night. why shouldnt i do a bodylift? |
The reason why I don't recommend body lifts. I don't recommend them because they increase the center of gravity. I know so does a suspension lift. But when you do a body lift you are putting a block between the body and the frame, a suspension lift you are raising the whole truck as one unit. In my opinion as well as alot of others, a suspension lift is alot more stable then a body lift. Also have you ever really seen the blocks they use for a body lift. I don't know about you, but there is no way I would be riding around in a truck that has the cab spaced from the frame by a flimsy piece of polyureathane. I have seen body lift blocks crack, shatter, and just break of the shock they get when driving especially in the cold weather like I get here in Michigan. Now when I was younger and didn't know any better. I was making body lifts out of Hockey Pucks. But that ain't to smart neither. After the lessons learned and years of experince I just recommend staying away from a body lift when all possible. Besides that you have to make a custom bracket to raise the back bumper back up to look right.
