trans removal, install pointers needed. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-03-2009, 11:41 AM Thread Starter
slcpunk74's Avatar
So my dad and I are having a trans built for our 97 f-250. We are getting a trans from I.T.S., a local company that sell to some places around Utah. They are gonna do a tugger kit, 3 clutch converter, upgraded clutches, 5 pinion support(steel not alum), and a bigger cooler.
We have opted to put the trans in ourselves and I am just curious if there is anything we should watch out for. We have done engine and trans swaps but not too many on autos and never a diesel. Any general pointers other then those geared towards a noob would be great. Thanks guys.
99 X-cab short bed, lifted, 325/60/18, gauges, ts 6pos, dynomax race muffler, diy intake, ddm 6000k hids, custom prerunner stuff...
vvvv TOWS THE vvvv
1994 Toyota class 7 desert truck
slcpunk74 is offline
post #2 of 7 Old 06-03-2009, 11:58 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
the two top bolts are a pita cause the turbo is in the way. dont over tighten the tq, dont forget to hook up the trans lines and the usual stuff. i think its just as easy as a manual. but might be a bit heaver.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #3 of 7 Old 06-03-2009, 12:08 PM
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
just don't round off the flywheel bolts!
Typical cummins owner.
taylorking is offline
post #4 of 7 Old 06-03-2009, 04:51 PM Thread Starter
slcpunk74's Avatar
Thanks guys, good tips. I hope this goes pretty good. Anything has to be better then my damn toyota 3.4v6 engine swap.
vvvv TOWS THE vvvv
post #5 of 7 Old 06-08-2009, 01:40 PM
also as a rule from doing this everyday on a diesel use locktite on the converter bolts as well as the bell housing bolts , small dab will do. I can't tell you how many diy guys bring there trucks in here after installing them selfs with bolts that work there way loose
2006 F250 KR 5inch exhaust, banks 6 gun
philcam01 is offline
post #6 of 7 Old 06-08-2009, 01:55 PM
20stroker02's Avatar
Don't be under the tranny when you break it loose, they are too heavy for a standard tranny jack so just be careful. Also, you should post up some pics of that 74 Bronco
2011 F350 CC/SB Ultimate Lariat FX4, Black on Black
Leveled w/37" Nitto Trail Grappler
20" Badlands
USMC
20stroker02 is offline
post #7 of 7 Old 06-08-2009, 02:10 PM
cchase's Avatar
make sure you have the TC seated right, if you dont you will tear up your pump. i believe it should slide back on notches twice? the other trick is a level across the bell housing, it should sit back an 1/8 inch
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
