Help with changing trannie fluid - Ford Powerstroke Diesel Forum
Old 05-19-2009, 01:17 PM
I got a new filter and gasket set so i could change my tranny fluid. Problem is i cant find a way to drain it or how to refill it. I have a 97 obs 4x4 so any help would be exlreamly greatful.
Old 05-19-2009, 01:23 PM
you have to take the pan off to drain it and get to the filter under the pan. its a huge mess so use a big azz drain pan. leave one loose bolt holding the pan up untill it drains most of the way that helps alot with the mess! you will re fill the tranny with a skinny funnel through the dip stick tube.
have fun.
