96 f350 Problem shifting from 1st to 2nd
My truck has 198k miles on it and recently it has decided that it won't shift from 1st to 2nd unless you let off on the throttle for a moment then it shifts fine. The shift from 2nd to 3rd is fine. I just replaced the filter/fluid and no change. Any ideas?
X2 on this. My dads truck just started doing the same thing.
mine revs out 1st then bangs into 2nd im clueless too
check trans cooler to see if it is pluged and if not u probly need new clutches just rebuilt mine for the same thing but trans cooler got pluged after and burned up the new tranny so make sure u clean the trans cooler
had a similar problem w/ my 96er years ago, ended up being that my fuel pump was going out. suggest checking your fuel system.
NITROXGOD.....did you ever get this problem resolved? I have a 96 doing the same thing from 2nd to 3rd.
I got a ZF5 and don't know much about the autos but keep bumping this thread. I'm gonna post a link to this thread in OBS chat so one the gurus can help you fellas out.
I would agree from above. something internal might be out or going out. Might even be a rebuild is comming up.
solenoid pack.....
no i never did figer it out because every time i get close something breaks i would suggest upgradeing to a 4r100 trans instead of the e4od because if u get one out of a diesel it will bolt up or just upgrade i put almost ever performance trans part in mine and it still breaks ATS and suncoast are good
