Clutch recomendations - Ford Powerstroke Diesel Forum
Old 04-11-2009, 11:38 AM
Exclamation Clutch recomendations
The father inlaw has a 94 F250 HD 7.3 PSD. 5sp manual
He tows a 28.5ft 5th wheel. He is not sure what clutch the last shop put in but it is starting to slip even without being loaded and only has about 25k on this one.
What would be the best setup for his truck?
Old 04-11-2009, 02:42 PM
e1?
Old 04-11-2009, 02:49 PM
shaking things up
i have a southbend clutch and love it a con ofe cluch and love it!!!! do the solid mass flywheel mod while you are in there it will make a huge difference you will like it!
Old 04-11-2009, 02:58 PM
southbend or valair are my top 2 choices... you can find both here Clutches
Old 04-11-2009, 03:08 PM
shaking things up
what all is done to his truck?? if it is close to stock i would still go a little heavier than stock and get the con O clutch and single mass conversion kit. You will probably get better mileage before it starts slipping IMO. southbend all the way!!!
Old 04-11-2009, 08:50 PM
His truck is bone stock.
Old 04-11-2009, 09:19 PM
Just got his old invoices for the clutch that was installed.
LO7154 conversion clutch kit
LFW140 conversion flywheel
E1 know these part #'s
Old 04-11-2009, 09:36 PM
My truck was bone stock when I bought the southbend clutch and single piece flywheel and it was to this day the best thing I could have done for this truck. I think it is rated for 350 HP and 700 ft. lbs. torque. but there are different levels obviously. Seemed like it changed my shift points and the truck just wanted to roll. I lug the hell out of the clutch now with the new mods and still could not be more happy with it
Old 05-11-2009, 05:30 AM
not to bring up an old thread, but i have a 94.5 PSD with ZF. Im doing a tranny in it soon, and i see all this about flywheel conversion to a solid setup? i thought that the older psd's had the good flywheel and the 97+ had the dual mass flywheel? My boss had a 97 PSD and his truck was at the dealer yearly for clutch issues.
