6.0 l cooler
Has anyone bolted in a 6.0l trans oil cooler in their OBS. I know the hoses are different but does the cooler slip in?
The bracketry holding your factory cooler, holds onto the pipes of the cooler, so if you think you can make it work, then sure.
I have a larger cooler in my PSD, with upgraded lines, and fittings. |
Looks like yours covers about alf of the radiator area. I believe the 6.0 covers most of the radiator. What is the braided line going to the trans? Ordinary aren't they rubber from the factory and hook to steel pipe that goes back?
they are usually steel line. and then to rubber line from the steel line to the coolers, and same on the way back.
