96 ZF5 5TH gear noisy - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-12-2009, 12:33 PM Thread Starter
screech's Avatar
I was just wondering if anyone has had issues with their 5th gear . I have a bearing type noise cruising at speed. It quiets up on accel and decel, but while maintaining speed it is constant. I think it is getting worse but very gradually.
96 350 Reg.cab 7.3 5sp. 4x4
3.5 to 4in dp, 4in strait pipe
4in Superlift w/ Airlift airbags on 315/75/16 Procomp X-Allterain W16x10Procomp wheels
Ba### Technicooler(the bad word)
Boost & E.G.T. Guages
Superchips programer(for now)
fpr mod
d.i.y. intake
South Bend clutch
79 150 4x4 (my wheelin truck)
420ci M motor,c6
4in lift, 35x12.5x15 Mud Terains
was old driver too much $$$--6-9mpg of premium(11.5to1)
screech is offline
post #2 of 7 Old 02-13-2009, 05:07 PM
97powerstroker's Avatar
Quoted: 14 Post(s)
nope,ive never had a problem yet,although i do need syncros,just afford to have it done.
2002 F-250 7.3 auto CC/SB lariat 116k miles, 6.0 trans cooler the rest is stock.
1996 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #3 of 7 Old 02-13-2009, 05:09 PM
strokerguy's Avatar
could be the throw out bearing
99 f350 reg cab 4x4 zf6 speed stock for now
strokerguy is offline
post #4 of 7 Old 02-16-2009, 01:55 PM Thread Starter
screech's Avatar
Most of my experiences with t/o bearings are not gear specific. I was just curious if anyone has had the same problem. Thanks.
fpr mod
d.i.y. intake
South Bend clutch
420ci M motor,c6
screech is offline
post #5 of 7 Old 02-16-2009, 03:56 PM
is it possible that it is also present in 1-3rd gears, just can't hear it over the motor? if it is in 1,2,3,5 and not 4th then it may be the pocket bearing between the input and output shaft. I had that go bad once and the sound was like a light whirring sound. the thing is in 4th gear the input and output shafts are spinning together.
Just a thought.
99 F350 CCLB 67k miles.
Sold: 01 Dodge cummins ECLB a few more mods to 353hp
Sold: 97 F250 SCLB, 5 speed 2wd. minor mods to 327hp
See a pattern? next I will have to find one of those 6 door jobbers...
Big Bird is offline
post #6 of 7 Old 02-16-2009, 03:59 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Maybe the bearing in the 5th gear is going bad!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #7 of 7 Old 02-17-2009, 02:28 PM Thread Starter
screech's Avatar
I am not shure, I never had one of these boxes apart. Thanks for the input. I'm not ready to pull it yet either, maybe spring. Any links to the brakedown of a ZF5?
fpr mod
d.i.y. intake
South Bend clutch
420ci M motor,c6
screech is offline
